2003 F550 6L batteries not charging, instrument cluster not working
Old 10-13-2014, 10:08 PM
Jas_d's Avatar
Jas_d
Jas_d is offline
I have a 2003 F550 6L diesel flatbed truck. Last week, the overdrive button would activate by itself. I'm assuming there was a loose wire so I taped the button to keep the overdrive off. Two days later, the overdrive came on while the button was pressed in and then smoke came out of the steering column/lever area. I pulled over and turned off the truck. The smoke stopped after 10 seconds and I restarted the truck. The overdrive light/functionality no longer worked and the instrument cluster also wasn't working.
The next day I was driving, and the truck died at a stoplight. I got it towed home, and opened the steering column and noticed that the overdrive button wire had burned. I removed the harness clip and charged the batteries. It started but the instrument cluster still didn't work. 2 minutes later the truck died. I replaced the alternator but still it won't charge the batteries. The truck dies 2 mins after getting a battery boost to start the truck. The instrument cluster also doesn't work. Can anyone provide suggestions on what could be causing this issue?
Jas_d
Electrical Systems/Wiring
10-15-2014 11:45 AM
Jas_d
1999 to 2016 Super Duty
10-13-2014 07:45 PM
stscable
12-07-2007 10:53 PM
Quick Reply: 2003 F550 6L batteries not charging, instrument cluster not working
