I am thinking of mounting a ViAir Compressor and air tank on the rear side of my truck bed tool box. Given it is an 8' bed I should have plenty of room between the compressor and fiver hitch. This way if I move the tool box my compressor goes with it. So what do you think?
I have my viair compressor and tank mounted in my tool box, i like the set up a ton. I keep a lot in it and 100 foot goodyear air hose.
I left room because I am soon upgrading to a bigger tank. Would like between 5 and 7 gallons. I have my compressor wired to upfitter 1 and it's left on most if the time, it cuts off at 150 psi.
I do have a tonneau cover but aren't they exposed when mounted under the truck?
They are. But that is why I mounted my compressor under my back seat. I live in the salt belt and plow in the winter. Didn't want it rusting away after 2 years.
We are putting bags on the rear of our new truck too. Is the tank really needed? How long does it take the pump to pump up a couple little bags? What is the better valves/controls out there today?
I run bags with no tank also. Doesn't take long at all to get them full. To go from 10psi to 30psi takes about 10 seconds. So I would say from 10 to 100 around a min or so.
My set up is a 2 gallon tank. Takes about 30 sec to fill. I have that tank then run to train horns on my truck, as we'll as for the 100 air hose incase I have any issues at the farm or my pull behind. Also makes putting up fence easy.
