03 no start nada
10-13-2014, 04:30 PM
03 no start nada
Turn key and nothing happens, no click or crank just silence. Dont know if its normal but theft light blinks rapidly. Ideas??
10-13-2014, 05:10 PM
I tried jumping it but still silence. No codes via SC
10-13-2014, 05:12 PM
on
Dash lights come on?? Try moving the gear lever to N and try.
10-13-2014, 05:17 PM
Tried that Eric, even kissing starter with hammer. Also tried turning all switches off/on. Hate walking to San Fran at 5 am
10-13-2014, 05:20 PM
on
Quote:
Originally Posted by
hanklin
Check fuses? May try a different key
10-13-2014, 05:34 PM
Wife at first day of work in eons and took my key. This did happen a long time ago (I forgot,till son just reminded me) and said after it sat a bit it was fine. I coulda swore I replaced batterys
10-13-2014, 05:38 PM
on
#113 I believe. 30 amp. Does the dash light come on? Check and make sure battery connectors are clean and tight.
10-13-2014, 05:39 PM
Dash lights are good as are connections although I will go check fuse
hanklin
Turn key and nothing happens, no click or crank just silence. Dont know if its normal but theft light blinks rapidly . Ideas??
PATS not allowing it to start? Try the key your wife took.
10-13-2014, 05:43 PM
You can also try turning the key to the run position and turning the engine over as shown in this video to see if it will start,
10-13-2014, 05:55 PM
10-13-2014, 05:57 PM
I will do Brett but I know both keys were tried this a.m
10-13-2014, 06:05 PM
Brett, I did what Ron in video said and it cranked over evenly. Now what? Wife home in an hour with other key but I know she tried it this am.
10-13-2014, 06:12 PM
Confused. Are you saying to key on then tap wire? Diesel Ron was saying key off.
