Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 10-13-2014, 02:22 PM
POPAJON POPAJON is offline
POPAJON is a splendid one to beholdPOPAJON is a splendid one to beholdPOPAJON is a splendid one to beholdPOPAJON is a splendid one to beholdPOPAJON is a splendid one to beholdPOPAJON is a splendid one to beholdPOPAJON is a splendid one to behold
1977 frame
HI Gang......I need some help here.... again. Just bought a rolling '77 F-150 2wd frame way up here in Ontario Canada. Which was originally from Georgia. The problem I have is the front cross member (where the engine sits) is pushed up on the right side, like the PO had ran into a large rock, tree stump or some other immovable object. I want to find out if the frame is been bent or racked. Is there a point. on the frame, that I can start my measurements from? I only paid $150 CDN for this so I don't believe I lost. I want to replace the frame on MY 77 cause the left side front rad saddle support was bent al the way around to the tire. I can cut the good part off the Georgia frame and mig it to MY frame, or heat and bend the engine support cross member back into place on the Georgia one. Any help is appreciated.
Old 10-14-2014, 02:21 AM
privateer, eh's Avatar
privateer, eh privateer, eh is offline
privateer, eh is gaining momentum as a positive member of FTE.privateer, eh is gaining momentum as a positive member of FTE.
Maybe check with flowney, he just rebuilt a wrecked frame and I'm sure he took a lot of measurements.
Similar Threads
New in West Georgia FiftyF6 New Member Introductions 4 03-30-2014 08:58 AM
78 F150 front axle 66 F250 1973 - 1979 F-100 & Larger F-Series Trucks 13 01-27-2012 11:40 PM
Frame straightening ideas ford_nut 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 02-21-2008 06:22 PM
Dual exhaust from a 226 flat 6 ksmith203 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-15-2007 07:41 PM
frame tweaked.. can i fix? create 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 06-07-2006 06:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
