What to do with virgin 01? Look Tugly
#151
Yes they do. I think part of the reason they install those filters is to provide sca additive to the coolant over time to keep the ph level right.
#154
#155
on
You might be able to get there...but don't bet on it due to your heavy load in the long back. Also, you have tow mirrors (-0.5 mpg), big AT tires (-1 to -1.5 mpg), your lift (up to -2 mpg) etc. Have you recalibrated your speedo to the larger tires? I know 285's are about 4% farther distance, so that can screw up your calculation and your actual mileage may be 4% better...or approx +0.5 mpg.
#156
Stock size tires? and I believe they are HT would have to look again. Lift?
I have pretty much all the motor maintenance and stuff to go threw yet before I can really see what we are going to be getting. I know the up pipes have leaks in them, I can't tell how bad, doesn't look to bad but I can only see a little bit around the pipes. Possibly boost leaks yet too, I also haven't checked that yet. Lots of things to get into yet.
#157
Sorry for the late response but if the OP didn't get these answered:
A CA 7.3L with an automatic transmission did not come with a cat (some of the early ones of this generation might have gotten one in the 99-00 range). There should be an emissions sticker under the hood that says 'catalyst not required'.
My 285s put my speedo as close to dead on as I can get (according to my Garmin GPS). The 265s had my speedo a little high (by about 2-3mph at freeway speeds).
#158
Trucks are supposed to have 265's stock? Sorry I have not looked at the door tag at all in this truck yet.
My excursion has 285's stock, I just thought the was what was on superduties 00-03.
I keep meaning to take the garmin along to check the speed because I question the tach. In my X 70mph is dead on 2000rpm maybe pushing 2050. In this truck for some reason 70mph reads 2200ish rpm's. I know when you start going over 2000rpms the mileage drops off quick.
#159
#161
I tried going with door-sticker-sized wheels, but Stinky would twerk when passing, so those came off the next day. They also made Stinky look like one of those Tootsie Pop women at Wal*Mart.
Important note: The air pressure on the door is for those skinny stock tires. When changing tire size, you need to refer to the manufacturer's inflation guide, not the door. I estimate our noses are between 4000 and 4500 pounds with a driver, passenger, and an empty bed - so properly airing the front tires need a little homework.
#162
#163
#164
My truck's front end weighs 4400lbs (full tank, empty bed and nobody in the cab).
Toyo has a .pdf that explains more than you ever wanted to know about tires and load capabilities. There's an equation to extrapolate your tire's load capabilities at any pressure. There's also a chart towards the bottom that does most of that for you for just about any type and size of tire.
This is what I use when I'm not loaded or towing so I don't always have 80psi in the tires and wear down the center rib section of my tires prematurely (I only get 35-40K out of my mud tires if I take really good care of them):
http://toyotires.com/sites/default/f...-LT_102913.pdf
#165
I feel reassured that my estimate was so close. There will be a significant difference between 2WD and 4WD, though.
