What to do with virgin 01? Look Tugly
#39
Thanks for the complements! It is slow going but it will get done eventually. I am pretty much done with the rear extension now. Just have a side saddle to build to hold the oxygen tank and then I can move onto the truck stuff like in tank mods, chassis saver, and whatnots.
Is it worth it (mileage wise) to dump the stock exhaust for 4"?
#40
#42
#44
I want a surface rust to build up so it etches the metal for the chassis saver to soak into/adhere to.
Out of all the different preps and tricks I have tried over the years, I found that a simple surface rust (slight pitting) is the absolute best base for chassis saver/por-15 to stick to.
Even with their metal prep stuff and following every letter of the directions to a T nothing works better than some rust itself.
Yesterday I finally got the last of the mill scale off the new frame sections (vinegar isn't as fast as I thought it would be). So now I can finally let it sit and rust/etch.
I think next time I will just pick up some muriatic acid or something and try that. I did have some hydrochloric acid but apparently that stuff weakens over time to the point that it won't even dissolve a french fry.
#45
