2015 High Idle
2015 High Idle
I've read a few threads on here on the high idle mod but they all seem to be for the earlier generation 6.7's. My dealer said that the high idle on the new trucks is now fixed and works good. Is it true that they now come set from factory and will idle at a high enough RPM to properly burn fuel and not cause buildup on the valves? Thanks
Q-180R4 is the only recent document I can locate on SEIC. I used a 12,000 Ohms resistor.
Really the only difficult part was finding the correct PCM wire with the hair thin color stripe.
https://www.fleet.ford.com/truckbbas...tml/q180r4.pdf
powerstroker100
04-26-2010 10:01 AM
