New to me 64 f100
What kind of gas would be best to run though that motor and would it be wise to use some type of lead additive?
I live in TN so I won't have to run that California crap through the truck but I was really hoping to run regular, I highly doubt it though. I think the octane levels here are typically 87, 89, and 93. could I just run regular and adjust the timing with the distributor accordingly or do I absolutelly have to run premium so it won't start knocking and acting stupid?
I live in CA and run regular with no additives in my rebuilt motor--no issues.
~Steve
You should be fine with regular if the motor is properly tuned and in decent shape internally. If the motor has never been touched (i.e. no hardened valve seats) some kind of lead additive couldn't hurt.
~Steve
~Steve
The 292 is a low compression engine, 8 to 1 and as such can run on **** and vinegar without knocking. That's a good thing unless you want maximum power and performance.
You still want to curve your distributor (or replace it with new probably) Trust Me. Start doing your homework on Y block engine advance timing, mechanical and vacuum, etc, and put your timing light on it and see where you're at right now. It's all right here in the archives, and a bazillion websites.
When is your vacuum gauge arriving in the mail or did you buy one already? Etc.
One thing to be aware of, you asked about this, on a 50 year old truck corrosion is your enemy in the starting and ignition circuits, lighting, everything. All the connectors and wiring will act more like resistors than conductors by now.
If it were me, start from the beginning of the maintenance and troubleshooting "bible" like the Motors Manual, and half a dozen others, and perform a compression check before doing anything else. Maybe it only has 13k on it, maybe it doesn't. If the rings are shot or valves burnt, then it's time for a rebuild on the motor. You'll want to know this, before getting spooled up about everything else! That way, you KNOW that a good solid engine is in there and ready for tuning.
Before you do this, be methodical and read everything you can on the subject. The internet is a wonderful resource, millions of web pages archived and downloads and YT videos, you can get up to speed on just about any basic procedure in a short amount of time."Effective use of source material" as the old man used to say.
Get the manuals suggested, and a compression gauge. Other tools that you'll need in no particular order - a grease gun, a multimeter, vacuum gauge, timing light, and a battery charger that will provide 4 to 6 amps to go with your new battery, jackstands, creeper, and a balancer puller.
Most of all, have fun, BE SAFE, and you can learn a lot and the knowledge is still applicable to the modern vehicles, there's more layers of BS but the basic principles are exactly the same, they just cause more expensive problems.
~Steve
I've got the 292 with a 4-speed t-98 behind it. Before I changed the gears in the differential (which were 3.92), I was getting about 12-13 around town. Changed the gearing last week to 3.23, so I expect an improvement, but it will be difficult to measure before I swap out the speedo gearing.
~Steve
~Steve
Thanks!
One thing, though--my truck has a lot of miles and the differential was completely shot. Some parts had disintegrated. It's definitely worthwhile opening it up for inspection.
~Steve
Okay new question.. I've got brand new disk brakes that I just put on the front and the origional wheels actually fit!!! Well sorta... But the spindles stick out just slightly to far to put my hub caps back in so could I just bang the grease caps in with a hammer or go with wheel spacers? I would really like to keep my hubcaps because there origional to the truck and still look almost new
Thanks again!
CJ
Thanks again!
CJ
'57 Ford F100 Nut
93
06-29-2017 03:35 PM
Slushdog21
11-14-2010 12:03 AM
MaGruff27
10-20-2008 06:32 PM
