Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-12-2014, 03:11 PM
shaggy6795 shaggy6795 is offline
shaggy6795 is starting off with a positive reputation.
Towing power
I recently had my e4od rebuilt by a friend who is a trans guy and master mechanic.now I towed my 27' boat back from the river having to go over 2 small mountains and my 95 bronco with 5.8 struggled to go up the mountain which is not super steep.When I told my friend the mechanic about this he said it sounds like a performance problem and not a trans problem. Does any one have any suggestions on what type of mods I can make to give me the power I need to pulling my boat.like cam or converter .2nd does anyone know of front disc brake up grade for 95 broncos maybe bigger calipers/bigger rotors
Old 10-12-2014, 07:24 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
What gearing and tire size does the truck have? 4.10's and 31" tires would be a good start if you have something other than that.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1994 3.0L 5-sp x-cab Ranger 3.45, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Old 10-13-2014, 04:58 AM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
I am the NRA and I vote
gatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud ofgatorfor88 has much to be proud of
How heavy is the boat? My cousin has an OLD 25 foot Stamas that weighs over 5600 pounds. Add trailer weight to that and it starts getting hard for any non diesel powered truck to pull. Broncos werent exactly designed as tow rigs.
__________________
78 Bronco Ranger XLT, 358, Edelbrock performer 400 and Holley 600 carb, Erson cam. Ugly, but DAMN FORD TOUGH Speak softly and carry a large caliber. Bring them home NOW! Get out and vote or kwitchyerbitchin.
Allen
Old 10-13-2014, 10:23 AM
Quote:
the boat is 27 foot scarab with a 502 blower motor and a aluminum I beam trailer duel axle. I don't think it comes close to your cousins stamas.believe me I know my parents own a 32 foot stamas and they seem to all have pretty thick hulls.I think I'm about 3200 lbs
Old 10-13-2014, 11:20 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.
like mentioned what size tires are you running? how did the boat tow before the trans upgrade?
__________________
94 XLT 357/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG AT's
4.88 gears/Aussie Front/rear open
Edelbrock efi intake JBA shorty,CustomY pipe/exhaust
http://www.supermotors.org/registry/...il.php?id=4158
Old 10-13-2014, 12:08 PM
Quote:
running 35" tires I never towed this boat with this truck but I have used it to tow my other boat which is a little smaller but close to the same weight
Old 10-14-2014, 09:16 AM
ok so your running 35's, what gears are you running? if stock that is your biggest issue and should be at least 4.56 if not 4.88's like what I run if you want to tow with out straining not only the engine but also that new tranny you have installed.
__________________
Old 10-15-2014, 03:33 AM
What's the the ride like on the highway like with 4:56s? Does it whine at high speed? The gas mileage must suck.what about installation of a beefer converter.
Old 10-15-2014, 09:06 AM
I run with 4.88's. there is no whine at hwy speeds,only pourly setup gears will have a whine.
Gas mileage has changed slightly. I average 10-12mpg city and 14-15hwy depending on conditions traveling at 65mph.
changing your converter wont make any difference. same goes for any engine mods short of a supercharger that would give you gains in performance to overcome the lack of gearing you have. Understand your not only turning a taller tire but also a heavier tire.
The gearing I am running was selected because at the time we towed a 5000lb travel trailer for camping and I wanted the extra gearing to assist with this and take stress off the engine and trans. I can set the cruise (not towing) and it will hold even with a head wind and the trans wont need to downshift.
your year bronco having an overdrive trans is an advantage that others running a C6 for instance would put them around 3000rpms at 65mph.
offroad this ratio is awesome also, you feel like it truly has a low range given the behavior of a manual.
__________________
Old 10-15-2014, 01:29 PM
I've rebuilt the 8.8 rear end so I can set that up but the never the front diff.is it like the new rear diff.
Old 10-16-2014, 09:38 AM
I suspect if you installed new gears in the rear diff then doing the front would be similar.
__________________
Old 10-16-2014, 12:21 PM
exranger06 exranger06 is offline
exranger06 is starting off with a positive reputation.
There are two different carriers for the Dana 44: One for 3.73 ratio or higher (numerically lower) and one for 3.92 ratio and lower (numerically higher). So, if you're going from 3.55 to 4.56 or 4.88, you'll need a new carrier for the front axle.
Old 10-18-2014, 11:01 AM
Conanski's Avatar
Assuming your truck originally came with 3.55 gears and 31" tires, your effective final drive ratio with 35" tires is now 3.14 which is good for nothing when you only have 4 forward speeds to work with. The original tire/gear combo is OK for general driving around but if you want towing performance the truck would need 4.10 gears, but to get the same final drive ratio with 35" tires you need 4.56 gears.
__________________
Old 10-20-2014, 06:23 PM
I have set up the rear end on the 8.8 but never the front Dana 44 is it much different in tolerance wise.its bad enough I have to take both Axel shafts to get it out
Old 10-21-2014, 12:07 PM
when you say you rebuilt the 8.8 what exactly did you do? did you completely replace the ring and pinion?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
First trip towing in mountains F250Dave 2009+ F150 19 06-19-2010 08:53 PM
99 F250 SD Transmission problem kart11 Super Duty & Heavy Duty 5 06-01-2010 06:10 AM
2001 Expy 4.6l Power expectations question jeep8589 Expedition & Navigator 7 03-22-2010 07:31 AM
Would like Bigger Brakes BC Powerstroke Super Duty & Heavy Duty 3 06-04-2009 03:35 AM
97 f-250 powerstroke power problem m14dan 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-02-2007 01:04 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
