Help Please - Fuel Filter Change
Old 10-12-2014, 01:03 PM
waggdr's Avatar
waggdr
waggdr is offline
Cool Help Please - Fuel Filter Change
OK... 2011 6.7 Diesel F350... changed both fuel filters today. On the top filter on the inbound side... their is a hose which comes in from below and attaches to a black plastic "vent like" fitting.
The hose and fitting broke off.... what is the piece that attaches to the inbound upper fuel filter called? I need to replace this piece and reconnect the hose...
Old 10-12-2014, 01:22 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
sorry, not sure where u are talking about..
under chassis or engine bay?
Old 10-12-2014, 02:02 PM
waggdr's Avatar
waggdr
waggdr is offline
Engine bay -- what attaches to the inbound side of the fuel filter? That has a black hose which is attached to a plastic fitting (which broke off)... not even sure what the part is called.
How do I attach a picture??
Old 10-12-2014, 02:08 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
So did you snap the piece off of the top of the cap, or are you speaking of the connector line itself?
Old 10-12-2014, 02:09 PM
Sailor Roy's Avatar
Sailor Roy
Sailor Roy is offline
Received 3,934 Likes on 1,574 Posts
One thought.........
Go to the dealer........they have all the diagrams. Then you are there to pick it up or order it.
Old 10-12-2014, 02:10 PM
waggdr's Avatar
waggdr
waggdr is offline
Old 10-12-2014, 02:12 PM
waggdr's Avatar
waggdr
waggdr is offline
See the picture above.... loose hose attaches to the black fitting on the inbound side of the fuel filter.
A while back, the Ford dealer worked on this area as I had a fuel smell in the cabin... note the markets on the same area. I have never touched this area until today -- I'm wondering if it was cracked and just broke off.
I'm not even sure what to call this piece... any one know?
Old 10-12-2014, 02:15 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
I don't know what the actual piece is called, but I do know what you are speaking of. One end connects to the fuel line, the other to the fuel filter and there is a T-fitting for the line that is loose in your photo.
I would be willing to be this will be a dealer only part.
Old 10-12-2014, 03:52 PM
kper05's Avatar
kper05
kper05 is offline
Are you referring to the piece between the yellow and clear clips?
I think that piece detaches from the filter and the yellow flex tube.
Take that and the picture to your dealer and see if you can purchase that part.
I don't know what it is called either.
Probably a slim chance but you'll want to make sure any openings around that area where it broke are free of plastic bits.
Old 10-12-2014, 04:05 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Sorry to be the bearer of bad news, but if you snapped that part, you better keep your truck parked until that part is replaced. The part you refer to, that tees into the the line and the secondary filter is all one part of the main fuel injector fuel return hose assembly. The part number from Ford for this part is BC3Z-9A564-B. Have fun replacing it too. Believe me when I say this is not because I think, it is because I KNOW.
Old 10-12-2014, 05:21 PM
waggdr's Avatar
waggdr
waggdr is offline
Part found
OK... thanks for all the replies. The part I'm looking for is the one below, and it appears to have been redesigned (for good reason). Now, does anyone know how to disconnect it from the yellow attach point in the first photo I sent? Is it as easy as pressing down or pulling up on the yellow?
Part
bc3z-9b246-a
Old 10-12-2014, 06:17 PM
Sailor Roy's Avatar
Sailor Roy
The yellow plastic clip (same as blue ones)
The easy directions are located at the following link.
This link is for a 3rd party fuel filter/water separator. Ignore that.....at about 2 minutes into the video the guy shows how to operate the clip.
Lift up on the clip.....push down on the thumb piece.....pull off.
Old 10-12-2014, 06:25 PM
waggdr's Avatar
waggdr
waggdr is offline
Much appreciated... thank you.
D
Old 10-12-2014, 06:38 PM
Sailor Roy's Avatar
Sailor Roy
D
You are welcome........Hope it helps !!
Old 10-14-2014, 07:10 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
You won't break any more, will you Roy?
Quick Reply: Help Please - Fuel Filter Change
