PS pump & AC clutch
10-13-2014, 02:27 AM
on
Glad you made it home safe Glenn. Now to get the mare bigger and better for next year.
10-13-2014, 10:11 AM
haha Gabe, I do have a 'small' list of stuff for getting done this winter!
Anybody have a 'how it' on the ac clutch? Also, is this a dealer only part?
10-13-2014, 11:53 AM
It is easy Glenn.just the 8mm center bolt to remove the hub,there can be a spacer used to adj air gap,then a snap ring for the coil . I would pull it apart and make sure the snout the coil resides on is not damaged.that will determine if you need a complete unit.
I'm pretty sure ford used to at least sell clutch seperately.also aftermarket I would think can get too.
10-13-2014, 11:54 AM
I have one here that has the clutch and coil off if you would like a pic of it apart.
10-13-2014, 12:12 PM
That would be great Aaron, thanks! I'm assuming to get the 8mm nut off, you have to hold that ring behind it somehow?
10-13-2014, 01:18 PM
They generally aren't too tight.I use my little air ratchet or electric impact.its like a 6mm diameter bolt.
I'll go snap a pic and be right back.
10-13-2014, 01:45 PM
ok, that is with the front hub off already.I used it for a limmo ac reapir lol
that is the retainer bolt,the washer is a spacer that can go behind the front hub to change the air gap between front hub and the pulley assy.
10-13-2014, 01:57 PM
pulley and bearing,held on with a snap ring.
the surface where the bearing goes if the bearing locked up will be damaged.that will require a compressor to be replaced.
the coil there is just knocked onto a surface. I use a small dead blow mallet and it goes right on.
10-13-2014, 09:22 PM
Alright, thanks buddy! Its starting to make sense! Probably be awhile before I can get to it, pretty crazy around here after being gone for six months. Lots of things to do! As soon as the honey do's are done, LOL!
10-13-2014, 09:57 PM
10-13-2014, 10:54 PM
10-13-2014, 11:18 PM
I'm knocking out that list a lil here lately. Got to make them deposits because lord knows I withdraw all thetime.
10-14-2014, 11:23 AM
I'll post a pic of my AC clutch that failed. If I still have it.
Bar None Diesel is working on a a PS pump upgrade for the OBS rigs you might want to check out.
10-14-2014, 12:03 PM
10-14-2014, 08:43 PM
Thanks Pete and Corey. I'll look into it more.
