Rollerizing possibilities ??? - Ford Truck Enthusiasts Forums
Old 10-11-2014, 11:44 PM
Phat-Ford Phat-Ford is offline
Phat-Ford is starting off with a positive reputation.
Question Rollerizing possibilities ???
Hello Folks ! Just wondered if some one could tell me if I need to do mods (besides computer re-write) to use a roller cam/lifters and valve-train on the efi 7.5 liter in my 94' F 350, I have used roller everything on an older style, carbed 460 with no issues, but that was a mid 70's block w/ dove heads. I've heard that these newer ones differ in some ways, so any insight would be greatly appreciated.......Thanks Folks !
Old 10-14-2014, 03:29 AM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Depending on your cam, the speed density system for your EFI motor will not handle the low vacuum created by a mild cam. This is why myself, as well as many others have resorted to a mass air swap which involves a fair amount of work, and different components.
Old 10-14-2014, 04:02 AM
Question Thanks cbakker !
Thanks for the input cbakker, what's all involved with converting to a mass-air system ???
Old 10-14-2014, 10:13 AM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
What transmission are you running? If it's an E4OD you need to look for a mass-air truck with the factory E4OD since the ECU and TCU are one unit. If it's a manual transmission, a EEC-IV Mustang computer like the A9L is easiest since there's so much support and documentation from the Mustang community. You could also use an ECU based on tuning support disregarding the transmission and then use a Baumannator TCU standalone control unit for the E4OD if you prefer that route.
Old 10-14-2014, 06:35 PM
cbakker's Avatar
The PCM harness needs to be modded for the injectors as well as be re pinned. The air intake needs to be modded to include a mass air meter. As mentioned, if you have an E4OD, the computer must be from a pre '95 f-series or bronco, with a 5.0 or 5.8. A tune will go a long way also to match your build. Have you already built the motor?
Link to C-6 rebuild and rollerization threads seattle smitty Clutch, Transmission, Differential, Axle & Transfer Case 0 10-02-2015 11:40 AM
f-150 help billyf-150 Engine Swaps 1 04-07-2015 03:22 PM
Rollerizing possibilties ??? Phat-Ford 1987 - 1996 F150 & Larger F-Series Trucks 9 10-15-2014 08:52 PM
rail rockers old farmer Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 10-05-2014 05:45 PM
Mechanical or Solid Roller camshaft in 557ci jamies460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 08-10-2007 03:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
