Need help with a computer
So I dropped a 5.0 from an '01 mountaineer in my 79 f100. I grabbed engine, harness, transmission, computer. Any suggestions of someone that could flash my computer to bypass the pats as I didn't grab the key and column. I live in the middle tn area so nearer to that would be better. Any help would be appreciated.
You could check with Torrie at Fast Parts Network. He's good with performance tunes but I'm not sure if he will disable PATS or not, or if he has a tuner solution for a 2001 FoMoCo.
-Rod
-Rod
BishopVagabond
10-12-2014 10:20 AM
