Can't get U joint off
I am in the process of pulling the engine and tranny from a donor vehicle.
I got everything unhooked, clip pulled off, fluids drained, etc.
But I absolutely cannot get the u joint off of the drive shaft or yolk of the transmission.
I tried a c clamp with a huge socket on the other end to press it through. I tried heating it up and using PB blaster. Its not even budging.
Anyone have a trick? I am sure there is something I am not doing.
If I have to, is it alright to cut through the driveshaft just to get everything pulled? At least then I could work on it without having to be on my back.
I'm lost. I thought you were trying to get the u-joint out of a cup on the yoke coming out of the tranny. To do that you pull the u-bolts and it usually comes right out, although I have had to pry it out. But you said "press it through", which I would think means you are trying to get the u-joint off the shaft.
Wait - Is the yoke on the tranny one that is splined? Have you pulled the drive shaft out of the rear axle? If so you should be able to slide the whole thing rearward and the yoke will come right off.
Just for future reference if you ever have to replace the u joints on your propshaft;
Pull the c clips,
Get a couple hardened sockets the same diameter as the u joint cap and set it against the cap and smack it with a hammer a couple times and the caps should pop right off then just tilt the u joint out.
To install the new one just slide the new u joint in as far as you can by hand, install the new caps (being careful not to drop the caps or the needle bearings could fall out) and use a couple sockets to hold one cap and smack the other socket in the other cap into to place, install the new clips.
Done it hundreds of times like that and works like a charm everytime.
Pull the c clips,
