351c 4x4 headers
351c 4x4 headers
i have a 76 f-150 4x4 that I'm swaping in a 351c and a aod. right now it has a 390, np435 and dynomax hedders. the dynomax hedders suck, the collecter is right in the way of the front d/shaft with a 6" lift. wen i put the cleveland in what hedders can I use? will m motor hedders work? or will they hang down to far
p.s. it's a 2v cleveland
351c 4x4 headers
Check out Sanderson Headers - they have several different styles of block-huggers that may work. And I do mean block huggers - the drivers side pipe on the ones I put on my 64 runs about 1 1/2" from the oil pan; if you have 6" or so between the pan and the shaft they may work for you.
DKW 86
10-15-2010 02:11 PM
HBINGER1
04-30-2003 11:12 PM
dustinleavitt2000
01-05-2003 01:34 AM
