66 250 DANA 60
66 250 DANA 60
hey guys I'm looking for a lead here.
Truck 66 ford f250 with 390 motor
4 speed trans
dana 60 rear end 2wd
i Believe the part I'm looking for is called a tapered dowel and it is installed on the hub just after the axle shaft slides in there are these tapered wedges that go in followed by a lock washer then 8 nuts to hold the axle down.
i need to buy more but can't find them thanks a lot
4 speed trans
1966 F250 2WD, Dana 60 rear end.
I believe the part I'm looking for is called a tapered dowel (Ford: adapter) and it is installed on the hub just after the axle shaft slides in.
There are these tapered wedges that go in followed by a lock washer, then 8 nuts to hold the axle down.
I need to buy more but can't find them.
PARTS INTERNATIONAL in Farmers Branch TX has 15 = 888-727-0418.
PERRY FORD in National City CA has 16 = 619-474-6451.
DON SANDERSON FORD in Glendale AZ has 67 = 623-842-8643.
Illustrated as 1142 in pic:
william16339
08-17-2015 02:52 PM
YoungFordAddict66
01-17-2009 01:59 PM
