No 4x4 w/ 2.7 ???
the 2.7 ecoboost puts out 385Ibs of torque, more than enough to haul things around. TFLTruck on youtube has some great video reviews about the different engine configs for the new ford. If you are not planning on towing much, the new 2.7 should give you the best combo of power and gas mileage. According to the reviews, Ford has added some advanced cam management (dual overhead, independent cams). Makes GM and Ram look like dinosaurs.
My problem is I am interested in the Lariat version and I prefer the technology package with the luxury package. Both of these can only be had with the 3.5 or the 5.0. That's it. I don't understand why this limit exists...it makes no sense to have put all this money into development and then limit the configurations.
My mistake. So you can get a 4x4 in a basic truck... Not that that does me any good. How is it that a crew cab is too much for a 325 HP 2.7 l? This is what is the disappointment.
You must have missed my post which included a screenshot of a crew cab 4WD 2.7L truck. Yes you can get them like that. Just not in a long bed.
When the last generation was being released, people complained about not being able to get the 6.2L engine in enough configurations. Now the same thing is happening with the 2.7L engine. Fact is, engines are usually restricted to certain combinations of options/wheelbase etc. This is nothing new, and nothing to be surprised about.
I am excited to drive the new 2.7L engine and compare it with the 3.5L EB.
The thread starter here is mistaken there are multiple build possibilities for the 2.7 and 4x4 capability.
However, I just read that the 2.7 has a PLASTIC oil pan and intake manifold - not in my truck it won't!!! If I order a new 2015 F150 it will definitely have the 3.5 or the 5.0.
Originally Posted by 2002 Series 60 Service Manual
The oil pan used on the Series 60 engine is made of plastic (epoxy vinyl ester) or aluminum.
For engines built after April 1999, a one-piece bolt assembly is used with the improved plastic
front sump and rear sump oil pans and a new isolator seal. The isolator seal is reusable.
See Figure 3-38. Old and new components should not be mixed
Yup. I had one, and it was far from useless. Of course some need a longer box, but most don't.
Sounds like you need to get yourself a new Ram then. Or perhaps a Chevy. Nobody makes a bad truck anymore, and instead of staying on here to gripe about what Ford doesn't offer why not go elsewhere and get what you want?
#28
5.5ft bed extended cab.
I have a 2006 F150 extended cab with a 5.5ft bed.
I think this is somewhat rare and no longer offered.
For maneuverability I love it. I like a short wheel base.
Not much difference in hauling 8ft 2X4s. Both the 6.5 and 5.5ft beds are too short for 8 footer`s.
