how do i replace door hinge (not just the pins)?!
Hello out there. 97 F250hd with bad driver's side upper door hinge. Gave it a new pin/bushing set and still didn't work. The hinge holes were worn and it couldn't hold the pin tight.
Does anyone know where to get info on how to replace the upper hinge? I took it off the body and now seemingly lost the piece(s?) on the inside of the door frame that the bolts screw into. I think I have to either take the dash out or the front fender.
This is a nightmare at this point!
the good news is that it's only 1 piece that you are looking for.
you are going to have to fish it up and back into place with a magnet. forget about taking the dash or fender off ... there are no access holes there.
it's a pretty silly design and it's hard to describe but you have to lift it up, position it carefully and then lower it into place . it just sits in place, held by 2 or 3 (or 4?) bent sheet metal "hooks". i went through this a couple of years ago ... while i was taking a phone call my neighbour did the fishing, and he got it done in only a few minutes, but i could EASILY see it taking much longer. good luck.
Yea, its a PITA to retrieve those backing hinge plates! I dropped the lower one when I had the door off the driver's side. I had to remove the parking brake assy to get more room in my 89 F250. I did use a bore scope camera to locate and help grab the plate, but still not fun pulling it up and out.
i woudnt put a magnet above ... it's upward movement that dislodges it from its cradle. a better way might be to slip a nail or stiff piece of wire in after you remove each fastener.
yeah ... i like this a lot better than my idea ! although mine will do if you cant find a suitable bolt.
Of course a junkyard will the expected answer, but mine needs to be replaced because the door-holder-open-spring-thingy broke and I don't really want a replacement that is worn. Anyone have a source for a reasonably priced new hinge?
Following this as my door-holder-open-spring-thingy (glad to finally learn the technical name for the whatz-it ) is broken on the driver side and hopelessly weak on the passenger side.
I was thinking of the idea of using a threaded bolt with the head cut off. I really like it. If you ground a bit of a taper on the end sticking out you could premount the hinges on door and use the tapered bolt to guide the door into position and hold it there while you got the other fasteners in. Or maybe I've missed something obvious as I've never pulled and reinstalled the doors.
LeoJr, I just found the answer to our problem. RockAuto.com carries a replacement door-holder-open-spring-thingy for $6.01 each. Search for part number 38435. They state that the door does not need to be removed to install it.
