2004 F150 4x4 front coil spring replacement
Sorry guys, I'm losing my memory fast. About a year ago, I replaced the front tie rod ends, ball joints, etc. I removed a 2" spacer lift that we had installed a few years ago. Now, I'm needing to finally replace the original shocks/springs (172,000 miles). I've got the new replacement OEM sized springs/shock assemblies on hand but am drawing a complete blank on what all needs to come off to remove/replace the springs.
Does the lower control arm have to be dropped? I've searched but can't seem to find a good step by step set of instructions.
Thanks in advance.
Thanks in advance.
Lower control arm can stay bolted to the frame and spindle, but the strut needs to be unbolted from the control arm.
Search for leveling kit install the steps will be very similar.
04+ Leveling Kit Install - Ford F150 Forum - Community of Ford Truck Fans
Got them replaced
Thanks for the prompt reply ZSK.
The link had some great pics. Once I started removing nuts and bolts, it pretty well came back to me. Got the springs/shocks changed out this morning.
On a disappointing note, I've still got a front end pop / rattle that is intermittent and coming from what I thought would be the front suspension. In the past year, I've changed out the upper and lower ball joints, inner and outer tie rod ends, control arm bushings, sway bar links and now, springs/shocks. I'm not sure what else remains. Maybe the pittman arm?
bumparker
1997-2006 Expedition & Navigator
01-18-2012 10:45 PM
Catalyst1
1983 - 2012 Ranger & B-Series
06-11-2008 08:01 AM
