Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 10-10-2014, 01:41 PM
Haydendh Haydendh is offline
Haydendh is starting off with a positive reputation.
Roller cam vs flat tappet cam
I'm trying to pick out a cam for my rebuild and have a few questions. It will go in a 77 F150 400 with 2.72 gears. When I do the rebuild I'm planning on running a eldebrock performer intake and edelbrock 1411 carb, hooker headers, one of the msd distributors, and Tmeyers piston kit.
So here's my questions , why are the roller cams so much more expensive?
The comp roller cam I'm looking at doesn't come with a kit so what all will I need to replace?
Would it even be worth the extra cost to run a roller?
The cams I'm debating on are -
Comp cam extreme energy 262h
Comp cam magnum 270h
And the roller cam comp cam magnum 270hr.
I have spent hours reading about the difference between the two and what others have put in theirs but I'm still looking for input. Thank you for your info.
Old 10-10-2014, 07:24 PM
SDDL-UP SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
Only you can answer the question "is it worth it?".
You CAN use factory ford roller lifters out of an older 5 liter engine, you need to install a "spider" in the lifter valley used to retain the factory Ford rollers. The cam will still cost more, but lifters from a salvage yard are cheap. Rollers don't really wear out unless something is bad wrong.
2.72 rear end gearing is really tall! You might want to swap those out, mileage will likely suffer, but I can promise much better acceleration, towing, climbing ability!
Old 10-10-2014, 08:12 PM
I planned on swapping out gears also , most likely to 3.44 . I'm new to all this so don't know what all that is going to entitle or how exspensive it will be. If I can I'm just going to swap gears instead of the whole rear end.
Old 10-12-2014, 09:51 AM
BuzzLOL BuzzLOL is offline
BuzzLOL is starting off with a positive reputation.
Quote:
. Roller cams used to be rare = expensive...
. Rollers now common in all new vehicles, but cam companies used to the big bucks...
. Flat cams usually iron... many rollers steel... premium rollers of premium steel... distributor gears and fuel pump lobes on roller cams may be different materials...
. Stock roller lifter setups have limited max lifts... .525" for SBC... Ford may be even lower, don't recall off hand...
. Roller lifters DO wear out... roller setups may be more reliable up to 100,000 miles or so, but a well broken in flat tappet setup may outlast them... because flat tappets wear on engine oil, roller setups depend on tiny overspeeded needle rollers...
. Stock roller cams start around $150 and stock lifters around $100... aftermarket cams about $200 & up, lifters about $300 & up...
. Your 2.73 rear prolly want a cam about 210/210 or lower...
. Could use a Summit cam until rear gear changed...
http://www.summitracing.com/parts/sum-k5200
http://www.summitracing.com/parts/sum-g6621-9
Old 10-12-2014, 08:25 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
Flat tappet's are simple and cost effective... but subject to failure if not broken in properly and if not run with high zinc (ZDDP) oil. Newer car engines are roller and catalytic converters do not like zinc so it has been greatly reduced in standard car oils.
The roller overcomes the "wiped lobe" syndrome at a high cost. Parts are more expensive, adapting to a non roller engine/block more expensive/tricky plus the issues mentioned above with distributor gears. A steel core roller cam wants a bronze distributor gear... which can be a short life piece.
Personally, I run and will continue to run flat tappet in my classics. Hydraulic in the dent and mechanical in the hot rod. I run high zinc oil and break in correctly and no problems so far. For the oil, choices are car oil + ZDDP additive, classic car oil (eg Brad Penn), some racing oils and diesel engine oil. I run diesel engine oil, Rotella T, since it is readily available and cost effective.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
a few questions for Cyl heads nflfreak43 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 29 06-19-2010 09:34 AM
Comp cams retro roller kit and dizzy gear fordzilla 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 12 11-15-2006 02:24 PM
comp cams 268h or 270m cam.....? zsir FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 07-08-2005 09:27 PM
HELP FAST! Need to order cam now! 1984_355w Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 20 07-01-2003 12:18 PM
roller cam setup ? scott9320 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 03-25-2003 10:25 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
