fuel pressure regulator
Old 10-10-2014, 10:24 AM
dcelrod's Avatar
dcelrod
dcelrod is offline
Has anyone ever heard of a fuel pressure regulator going bad on a 7.3 and causing it to stall after about 30 miles of driving and having 60 psi fuel pressure at start up?
Old 10-10-2014, 04:35 PM
fordpride's Avatar
fordpride
fordpride is offline
Ford it start right up when it stalls or does it take some cranking ?
Old 10-10-2014, 05:48 PM
dcelrod's Avatar
dcelrod
dcelrod is offline
It takes some cranking.
Old 10-10-2014, 09:39 PM
fordpride's Avatar
fordpride
Have you tried it on both tanks
Old 10-11-2014, 04:22 PM
dcelrod's Avatar
dcelrod
dcelrod is offline
Yes I have tried both tanks I have done the hutch mod to both tanks no the pick ups are removed from both tanks.
Old 10-12-2014, 09:17 AM
fordman67's Avatar
fordman67
fordman67 is offline
All there is in the regulator is a valve and spring. Are you checking fuel pressure while driving?
Old 10-14-2014, 04:36 PM
dcelrod's Avatar
dcelrod
dcelrod is offline
Yes its good until I get on the interstate and drive around 70-75 it will drop to 0 within 10 miles and die
Old 10-14-2014, 04:56 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
When was the last time you replaced the fuel filter.
Old 10-14-2014, 05:33 PM
fordman67's Avatar
fordman67
Pump or filter I would think.or sucking air at a quick connection
Old 10-17-2014, 07:46 AM
dcelrod's Avatar
dcelrod
dcelrod is offline
The fuel filter is brand new . now its unpredictable I thought that it was just doing it on the front tank. I had it running on the rear and run it up and down the interstate and it ran good I shut it off and then tried to go to town still on the rear tank and I got maybe 3-4 miles and it sputtered out and died so its doing it on both tanks and it is unpredictable when its going to do it could be 100 miles or 3 any ideas?
Old 10-17-2014, 08:51 AM
MOOSE_MACHINE
Well then I would think possibly air intrusion. But that's not the easiest thing to find. It will be somewhere between the selector valve and the pump. Probably on the quick connect by the motor or the small price of rubber hose between the hard line and the pump
Old 10-17-2014, 09:05 AM
dcelrod's Avatar
dcelrod
dcelrod is offline
The pump has just been replaced 2 days ago along with those 2 hoses from the pump to the filter housing
Old 10-17-2014, 11:43 AM
MOOSE_MACHINE
it won't be on the pressure side if it's air intrusion. It would have to be on the suction side. The best way to tell if it's your problem is a clear hose and look for bubbles but idk where you would put it
RSuperDuty13
06-25-2016 08:25 AM
Natcox012
04-08-2015 08:33 PM
muleyhunter
08-07-2013 12:15 PM
sleepyhead416
09-22-2011 09:41 AM
Quick Reply: fuel pressure regulator
