ECU Swap 5.8 to 7.5 advantages??
I have Been reading on this website(which I think is fantastic!) for a long time now debating the power upgrades of a 5.8 SD in an 89 F250. Massflow is fairly expensive swap, carbed loses starting ease and future tuning, and SD is set at what you have is what you got in terms of pre-programmed fuel adding parameters.
Question, If I build a 5.8 for max low end torque(350h-420t) while still utilizing the factory Sd syetem, could a 7.5 ECU be used to run the 5.8 upgraded with the 24# injectors since what I read is the 19# are limited to around shy of 300? I figure some wiring swaping in the harness etc.
Input from experience or knowledge?
Thank you.
Thank you.
frdf250
17
12-19-2009 01:58 PM
blaze42069
12-28-2008 03:14 PM
