And very easy to remove. (Maybe you already did) Adjust the mirror in as far as possible. Then, looking behind the mirror you will see a small metal clip. Using a flat screw driver, push the clip and the lens pops off. Might have to wiggle it a little from the outside while you push the clip in.
