1979 ford f250 no spark when cranking
Old 10-09-2014, 09:23 PM
dlburch's Avatar
dlburch
dlburch is offline
it may be brown on the I terminal....whatever color it is, do you have 12 volts there while cranking?
Old 10-09-2014, 09:25 PM
1979fordf250customs's Avatar
1979fordf250customs
1979fordf250customs is offline
Yes i belive so i can double check tommorow but im positive that tgeres 12 volts there
JWC 3's Avatar
JWC 3
JWC 3 is offline
Yes . You should have battery voltage to coil while cranking .
Old 10-09-2014, 09:34 PM
51M1's Avatar
51M1
51M1 is offline
Slow cranking can be caused by a badly corroded starter power cable.
Old 10-09-2014, 09:39 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 1979fordf250customs
Why are the listed as 351m and 400m?
FoMoCo never referred to the 400 as an M.
Then just out of curiousity, module is on the drivers side correct its a square lookin thing.
Scroll down to bottom of page in right pic: 400 VIN engine code is S .. Where in both pics is 400M? No see um.
Old 10-12-2014, 04:54 PM
1979fordf250customs
Hey do you guys have any more ideas ive gone thru everything on that found a melted plastic plug replaced it made a jumper wire straight from battery to tge coil and still only spark when it stops cranking over is it possible for the pick up assembly to be bad and have it spark when the key goes off
Old 10-12-2014, 10:01 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
I believe it is. When mine was acting this way I tried all of the easy stuff I had on hand and no help. As a last resort I finally went to Napa and got a pick-up coil and it solved the problem.....It may or may not solve yours. Good luck with it, I know what you're going though.
Old 10-12-2014, 11:25 PM
NumberDummy
D4PZ-12A112-A .. Stator aka Magnetic Pick Up Coil (Motorcraft DU-1A).
All 1974/79 V8 FoMoCo vehicles except 1979 LTD/Grand Marquis 351W with EEC
Old 10-15-2014, 01:42 PM
1979fordf250customs
so i pulled the dist apart and the pick assembly is broken into pieces how in the hell does it come off of the shaft tho im gettin a whole new distributer but i want to know for future refference
Old 10-15-2014, 02:53 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
Has a small wire snap ring... you can see it in the pic beside the vac. can.
Old 11-07-2014, 10:33 AM
1979fordf250customs
Alright guys so after a whole lot of playing with things i got sick of it and bot a whole new distributor and it runs fine the carb needs some tuning and theres some fine timing i need to do but after that she will be runnin like a champion
Coffeeman17
09-13-2017 07:53 AM
karen palmer
09-19-2014 08:13 AM
vera martin
04-15-2012 12:34 PM
Ranger GT2
Electrical Systems/Wiring
11-20-2007 11:54 AM
jdemoNC
13
12-31-2006 12:30 PM
Quick Reply: 1979 ford f250 no spark when cranking
