Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Old 10-09-2014, 12:16 PM
Don Vito Don Vito is offline
Don Vito is starting off with a positive reputation.
53-56 Smooth front inner fenders
I have a Volare front end and the inner fenders were hacked up for the upper A arms, and I've really been thinking about some after market smooth/custom inners, does anyone make them, I would think some nice fiberglass ones would be cool, has anyone fabricated their own? Pic of an install would be appreciated.
Don
Old 10-09-2014, 12:24 PM
gerrymoe's Avatar
gerrymoe gerrymoe is offline
gerrymoe is gaining momentum as a positive member of FTE.
Click the image to open in full size.
I made these to fit my flat firewall and Aspen front clip. This is the only picture I have.
Mid-Fifties offer a line of inner fender panels that fit the stock firewall.
Old 10-09-2014, 02:10 PM
2dasand 2dasand is offline
2dasand is starting off with a positive reputation.
Looks nice. What is an Aspen front clip?
Old 10-09-2014, 02:38 PM
gerrymoe's Avatar
Thanx for the like. It is Dodges version of the Volare, it is the same just different part #'s, mine is a 1976 Dodge Aspen.
Old 10-09-2014, 03:53 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to allCharlieLed is a name known to all
Here is a pic of my truck with the stainless steel inner fenders. If you have any mods at all to make to the stainless panels then pack a lunch...not the easiest task to get right. There is absolutely no benefit to fiberglass inner fenders...probably a good rationale as to why no one sells them.
Old 10-10-2014, 02:40 PM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
Charlie,
When you smooth the firewall as shown above, how do you determine how to align the inner fender brackets back up on it?
__________________
1956 F100
Old 10-10-2014, 02:46 PM
CharlieLed's Avatar
Quote:
Originally Posted by clintonvillian View Post
Charlie,
Measure the placement from the original firewall (if you look at my pic closely you will see the Sharpie lines I drew to mark the bracket location on each side)...that is with one exception, I don't place the mounting brackets ABOVE the inner fender panel, I place them below where they are not seen. I use a section of 2 inch angle and drill the holes once I have the inner fender in place. You can thread the hole, use a loose nut (not the best idea), weld a nut in place, or use a rivet nut which is my preference.
Similar Threads
Feel pretty good! Roelito78 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-01-2010 07:53 AM
Front wheel well splash guards Power Smoker 1967 - 1972 F-100 & Larger F-Series Trucks 3 06-08-2008 11:19 PM
front inner fenders Wayne S 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-05-2007 01:40 PM
Are Inner Fenders Needed with Fiberglass Fenders? GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 03-18-2004 04:35 PM
65 - 66 inner fenders fomocoloco 1961 - 1966 F-100 & Larger F-Series Trucks 5 09-29-2002 05:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
