144k Transfer Case Fluid Change
Yes, Mercon ATF in the trans and t-case. You can also use a full sythetic ATF. There is a fill plug on the driver side of the trans. Fill it up to that point where it starts to run out. The fill plug on the t-case is on the back toward the rear of the truck. The higher one is the fill plug and same as the trans, fill it until it runs back out that hole.
Questions:
1. I think I have read both, but what does the differential take - GEAR OIL or ATF?? I bought Valvoline Synthetic Gear Oil...then I thought I saw some other things written.
2. I am going to dump the tranny pan, tap it with a drain, and replace the fluid/filter...not problem there right - as I read above - old school was never touch it.
Thanks
bigbuck75
08-30-2015 08:45 AM
90pioneer
11-02-2011 08:49 AM
