PLEASE HELP Powerloss cant go very fast!!!
Quite unseal but it goes along with causing retarded ignition you would have saw by looking at the timing with a Scanner.
The timing wheel is part of the front crank pulley assembly the Crank sensor uses to reference crank position for all other functions.
The timing went extremely retarded causing the motor to lose power.
This would cause the exhaust manifolds to run Red and could even cook the cats.
Good one to find and good luck.
newbe-rebuilder
29
06-04-2010 05:38 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
10-19-2008 09:26 AM
