292 main rear oil seal leak
The 292 in my 63 F100 has a decent oil leak through the main rear seal, I had my local mechanic replace the seal but the leak is coming back right now I am loosing about a quart per 100-200 miles leaves a nice 5-6" oil slick after it has been driven around.
Any Ideas?
Any Ideas?
If it is, in fact, the rear main then it needs to be replaced again.
Many leaks are blamed on the rear main. So make sure it is not coming from some other part of the engine. Possibilities include:
valve covers, valley cover, rear most bolts on the intake flange, oil filter or oil filter adapter plate, oil pickup tube, oil pressure sender, any one of the oil galley plugs in the side of the block, oil pump, the two rear center oil pan studs (these should be studs, not bolts, and require thread sealer), cam plug, oil galley plug on the back of the block.
Many of those can drip down in nearly the exact same spot as the rear main.
Bolts won't really cause a problem but those two need thread sealer. And take care when tightening them because they are threaded into an aluminum retainer. The studs pretty well eliminate any risk there, though a hamfisted "mechanic" could still pull them out.
Make sure the pan rail is flat. When tightening the oil pan bolts, do not use a torque wrench. Tighten the bolts while paying attention to the gasket. If you torque them without paying attention, you'll probably squish the gasket out and it won't seal.
Any oil pan gasket set should work. Felpro is typically available at local parts stores. It's not likely that they will have it in stock but you can order it for pickup.
There are lots of opportunities in and around the rear main to leak as well. If your mechanic was not familiar with Y's, he could have missed sealing something up. Good luck.
~Steve
Still Leaking
Still leaking, I am going to pull the oil pan and replace it when I have a chance. the truck is now up for winter updating and will not be brought down off the blocks until April.
I have a pan under the leak and noticed that I have a mixture of stuff in the oil, think it is gas but am not sure but I have not noticed any loss in coolant. Could this be coming from the fuel pump? I did notice that the P.O. had a fuel filter installed after the pump and wondered about that because I think the fuel pump has a filter on it.
Sucks that it's still leaking. I still have a small drip after doing mine. (I think it's coming from the oil pump, though.) The fuel pump is pretty far forward of the rear main, so seems unlikely that you'd have fuel from there in the oil. Easy to diagnose with two separate drip pans, though. I had a fuel leak on a 390 (similar design) and the gas tended to drip off the bottom of the pump canister--it didn't migrate back to the rear of the motor.
Do you have power steering? Brake fluid level ok?
~Steve
