292 main rear oil seal leak
Couple of things
I do have a coolant leak, it is leaking on top of the crankcase under the intake manafold. Put another thing on my list to fix.
The crankcase ventalation system is not on the truck. I only have a bolt where the crankcase should be vented. could this be causing some of my oil leak problems by overpressurizing the crankcase?
The exhaust gas control valve is also missing on the truck, this is only a F100 with a two barrel carb so I do not see the engine being a heavy duty engine. Is it a problem that this valve is missing?
~Steve
Now What
Okay Re-checked the belly pan for the vent hole location and mine does not have one. Can I provide venting to the engine block like my 69 vett? provide a line from the air filter to one of the valve covers, take a line from the other valve cover to the intake manifold through a PCV valve.
You can do it like the vette. A pcv valve really is the best choice. You will need to add a baffle for the valve cover with the pcv valve to prevent it from pulling oil into the intake.
I don't recall seeing a valley pan that did not have that hole, unless it is aftermarket. Do you have a stock valley pan?
Plan B
Found a fitting from Jeg's that has a built in baffle, I am going to pull the intake manifold and the crank case cover and see if it is possible to install the fitting if it is I am going to use an in-line PCV valve and pipe it back to the intake manifold. If I get all the parts I will try to do this next weekend.
#29
#30
However, they do still have the provision for the road draft tube setup, which looks very similar, if not the same as far as fastening to the valley pan, which is why I find it odd that there is nothing there.
