Instrument Cluster Lights Out
Old 10-07-2014, 09:12 PM
ZackWarning's Avatar
ZackWarning
ZackWarning is offline
My 1995 F150's instrument cluster light stopped working a few days ago, i checked the fuses and they're all good, could it be the bulb or something else?
Old 10-07-2014, 09:35 PM
Dutter 2's Avatar
Dutter 2
Dutter 2 is offline
well best way to find out it take it out and see what bulbs are bad or if theres any bad wires, a wiring diagram volt meter will help
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Make sure you don't have the headlight **** turned all the way to the right...
Old 10-07-2014, 10:19 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
I had that happen once. The little wire in the headlight switch for the light dimmer broke. I just got a tiny pair of needle nose pliers and twisted it back together. It worked just fine for a few months till I got around to replacing the switch.
440 sixpack
11-16-2018 08:36 PM
77f100jacko
03-16-2013 12:11 PM
losingxinsight
24
09-30-2008 08:59 PM
tango54464
09-25-2006 09:31 PM
popman
02-20-2003 06:48 PM
Quick Reply: Instrument Cluster Lights Out
