1977 block into 1996???
It might be do-able, but your talking about a 20 year spread on engines, and having EFI now, back to a Carb'ed engine.
In my research, in the 90's era, '88-'93 were the next generation, and '94-'96 were the same, with the roller cam change.
Same being - heads, intake, exhaust manifolds and smog fitment.
Plus, your having to deal with the electronic sensors, along with the EFI working on the carb engine.
If your on a budget replacement, I'd opt out for a used engine replacement, in the '94-'96 range, with the roller cam, that way you have a "drop" in engine, and ready to go.
I just seen in our local Craigslist a guy selling a '95 351W from a Bronco for $400. good price, and a direct drop in engine. you would not even have to change the oil pan (from a 4x4 engine)
I'm working on getting my '92 running from replacing it with a '94 roller cam re-man, but I'm having problems with the fuel delivery, to keep it running.
Had no problems with all the accessories bolting on, and smog tubes bolted right up. Again, the same generation of engine block/heads.
The big difference is the roller cam in the 96 motor. You would either have to do a retro fit cam for the flat tappet block or find a similar flat tappet cam to use with the 96's computer. The 96 should be mass-air EFI, so that it can more easily adapt to the different cam. The 96 cam specs out like this: 256/266 advertised duration, .422/.445 lift, 116*LSA
93SVT
08-09-2015 12:02 AM
aj197816134
11-20-2010 09:22 PM
s1120
12-23-2006 10:23 AM
