Crush Washers?
Old 10-04-2014, 06:54 PM
Mercmeister's Avatar
Mercmeister
Mercmeister is offline
Crush Washers?
Hi -
I will be installing an Offenhauser 4 bbl intake manifold and factory Ford dual exhaust manifolds on my 300 six. I have read posts referring to "crush washers"? Are the crush washers the thick cupped washers used on the factory single exhaust manifold? Can they be reused or is it better to get new ones?
Thank you in advance.
Dan M.
Old 10-04-2014, 11:26 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
Yes, They are the thick washers that provide a little "springiness" to the clamping joint. They can be reused. I like to slightly chamfer their edges so they don't dig into my aluminum intake lugs.
Old 10-05-2014, 02:24 PM
Mercmeister
Thanks for the reply. Should I add regular flat washers on top of the crush washers? Do I need any type of lock washer?
Thank You,
Dan M.
Old 10-06-2014, 10:07 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
If you want to use the crush washers, definitely reuse the originals, since last I checked, Ford wants about $10 ea. for them. With 13 washers, that comes to $130. Ouch.
As for me, when I did mine, I ordered a set of super thick washers:
https://www.nutty.com/EXTRA-THICK-Gr...ers_c_427.html
Those are some hefty, heavy duty pieces too. I wasn't sure the size I needed so I bought 13 of two different sizes (both around 1" in dia). They worked great.
I got them a little bit bigger than the stock crush washers because they spanned the ears of the manifolds a lot better. The stock ones seemed to just want to nip the corners, which I didn't feel safe with.
Old 10-06-2014, 04:19 PM
Mercmeister
Thanks for the tip! Just an idea, but could I use standard thickness grade 8 washers underneath the factory Ford crush washers?
Thank You,
Dan M.
Old 10-06-2014, 04:40 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Buy the washers from an FTE sponsor and save a buncha bucks.
E7TZ-9443-A (replaced EAA-9443-A ~ D1AZ-9443-A ~ E6TZ-9443-A) .. Crush Washer-Intake & Exhaust Manifolds to Cylinder Head / Available from Ford
1952/53 215 / 1954/64 223 / 1961/64 262 / 1965/74 240 / 1965/96 300.
MSRP each: $8.16
FTE Ford Dealer Parts Dept sponsor: silverstatefordparts.com online price each: $5.39 / Gaudin Ford ~ Las Vegas NV
FTE Ford Dealer Parts Dept sponsor: horizonpartsguy.com price each: $5.88 / Horizon Ford Truck Center ~ Seattle (Tukwila) WA
Old 10-07-2014, 12:18 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Quite a savings. Thank you, NumberDummy!
Old 10-08-2014, 09:11 PM
Mercmeister
MSRP each: $8.16
Hi -
Looks like there is a bargain on eBay at:
http://www.ebay.com/itm/Ford-NOS-E7TZ-9443-A-Clamp-Pack-Of-Five-/201146994499?hash=item2ed54b8f43&vxp=mtr
Thank You,
Dan M.
Boombastic86
10-22-2016 06:55 PM
KsCop
10-11-2014 10:03 PM
shartman32
05-24-2010 05:33 PM
bmccartney
11-15-2009 04:05 PM
toque
04-15-2005 08:52 PM
Quick Reply: Crush Washers?
