Please HELP!!!
Lets get down to the issue. Do you have the wrong injectors installed or not? Do you have a Cali truck manufactured for that state? If so then the injectors are correct, if not then the injectors won't work good with the 48 state PCM, unless the PCM was changed, re-flashed, programmer, etc .. , then it becomes more complex.
More information is required ...
on
1 Post
You need to look at the code on the injectors. Are they AA, AD, AB, etc. Is that date something that someone has stamped on them? They could be AA injectors that were remanned 12/13. I've never seen a date on an injector other than one that was stamped on them. Get the code from the top of the injectors and go from there.
Look at the mechinical fuel pump, the Cali model trucks have a fuel pulse adapter (I think it is called) on it. Some say it looks like the Startreck space ship, but I have never seen one.
I found a cheap 95 motor I could pull the injectors on and put in mine but they have high mileage and mine don't. Also the split shots have more nozzle spray I believe. People told me i would be downgrading by putting AA injectors back in?
And somebody thought split shots would work where single shots belong. The stock AA injectors are smaller, but would operate correctly assuming they are good to start with. You could install a set of reman single shots that are a little bigger that would give you more power, even if you run with stock tuning.
#30
