1963 F250 4x4 power steering
So I've done some digging around but I have kind of a unique situation. I have a 1963 Ford F250 4x4 the previous owner swapped in a 460 out of the late 80s F250. It's running 37's which are a little unruly at low speed. I'm wondering what kind of options are out there with this set up to run power steering. Hopefully maybe somebody has done this before.
P/S was not available with 4WD until 1973, and then only Power Assist P/S was initially available.
Garrison Power Assist P/S: 1973/75 F100 4WD & 1975 F150 4WD / 1973 F250 4WD & 1974 F250 4WD before serial number T80,001.
Bendix Power Assist P/S: 1974 F250 4WD from serial number T80,001, 1975/76 F250 4WD, 1977 F250 4WD before serial number Y20,001 (last High Boy).
1976/79 F100/150 4WD's use Ford/Saginaw integral P/S as do 1977 F250 4WD's from serial number Y20,001, 1978/79 F250 4WD's & 1979 F350 4WD
Neither of these power steering systems will swap into 1959/72 F100/250 4WD's without a tremendous amount of modifications.
All the Power Assist P/S parts are obsolete, difficult to find NOS and expensive if found.
Please embellish on the late 70's bronco steering box mod to take the place of the 64 f250 4x4 manual box / one piece column?? Im about to pul the cab so, ya know.... Thanks -
Here is a shot of a 64 that i converted to front steer.Four wheel drive would follow the same principal.
Simple adjustable left and right hand drag link i made for the truck.
Here is with the box off and the upper rail modification.
Here is the box and the inner 1/2" plate mount.
The bronco box mounts on the outside of the rail and make a cross steer linkage. Or you can use a 2 wheel drive box and mount it on the inside of the rail and a straight up linkage.
Here is a later 79 2 wheel drive box on my 69 crew cab Highboy.
If you think it through it is a pretty easy swap if you can fabricate.
Garbz
Garbz
While reading this thread I had napass2004 steering thread in mind since it wasn't to long ago that he did the conversion. I never converted my 64 4x4 to power steering but I did convert my 71 crew cab highboy over using a 79 F250 4x4 box. Check out this this thread for an idea there's many ways to convert over just need to be creative and be able to fabricate. https://www.ford-trucks.com/forums/1...-together.html
I want to work out a solution to keep the closed knuckle 44 and same general location of the stock steering box...with a US manufactured box...wish me luck but I will be tenacious!!
I thought I replied to this,,,must be losing it (again). I hope to assemble a kit using my truck as test vehicle. The kit will include brackets, shafts, u-joints, etc. Hoping to go with a basic, readily available, off the shelf of auto parts store box and pump, we will see. It will take a while amongst the other work and life stuff that gets in the way of what I really like to do, which is work on this slick, plus I have my eye on a truck in Montana a certain someone is trying to sell.. Keep ya posted.
