Ford F150 One Piece Driveshaft Slip Bump- FIX!
#31
Is this issue only relevant to the 4x4 trucks? I have a 4x2 and the description sounds like what I am experiencing....
Just checked under my truck and I have what looks like a 2 piece driveshaft. It has a hanger bearing in the middle, and a bellows of some sort on the shaft directly behind the hanger bearing. Can the shaft be pulled apart by the hanger bearing and greased?
#32
#33
Any thoughts?
#35
I'm wondering if this is the same thing my truck is doing?
I have a 2011 F150, 4x2 Super Crew, with less than 40k on it. And I notice it more at a low RPM, basically just higher than an idle, like going through a parking lot. Then the "Bump" happens. To me it feels like the transmission suddenly hits another hear "HARD".
It will also happen when driving, then coming to a complete stop, then releasing the brake pedal and applying pressure on the accelerator (gas pedal). Other than that, no vibrations, transmission is smooth as silk.
Unk Bob
Unk Bob
#36
I'd recommend making an appointment at your dealership for diagnosis. While there, take your tech on a test drive so you can replicate what you're experiencing. Once you've had this checked out I'll be able to research some additional ways to help.
Crystal
#37
Unk Bob
Unk Bob
#38
I have a 2010 F150 4x2 Supercab with the 2 piece drive shaft. Pulled the rear shaft out today, cleaned up the splines (under the black plastic accordion/boot), and lubed it with a pack of the white teflon grease. Reassembled, and road tested. Smooooooooth as butter now!! No slip/bump at all anymore!!! Happy camper!!!
#40
Your dealership will be in the best position to determine if a repair can be made under your warranty. I recommend making an appointment so they can inspect; once you've had your visit I'll be able to research options to help.
Crystal
#42
Crystal
#44
#45
