Ford F150 One Piece Driveshaft Slip Bump- FIX!
I got a real good example of this concern in today and I show you guys. In this video I show what is causing it and just how to fix it. While this concern is well documented on the two piece drives hafts not much is out there specifically on the one piece drive shafts.
The following users liked this post:
most of the truck owners these days would forget to grease the driveshaft or complain that a modern truck still had a grease zerk on it.
Slip Bump!!!
Hi All,
Mine has done it for the past 2 years its a 2012 does it on Stop and Go the dealer says the service bulletin is for the 2 piece shaft,I mentioned to them about the nickle plating on drive shaft side of spline and having to use the teflon based grease on it,the service writter said that if i know the problem that i should fix it, needless to say we had some choice words and i never will deal with there Stealership again i have bought 6 vehicles from them through the years,time to take it to a dealership that gives A
Crystal
Hey fellas,
Purchased my truck new 12-28-2013. On 7-28-2014 I took my 2013 F-150 Screw to the dealer for transmission clunking. In stop and go rush hour traffic, it clunks between 10 & 30 mph. The dealer applied a transmission Technical service bulletin to the PCM/TCM (Powertrain control module and Transmission control module). I was told its a 'learning' transmission and the clunk would get better... NOT!
Sounds like the 'slip bump' issue would fix my truck as well. Great video and information.
Adios.
Adios.
I'd imagine it would wear to a point it will have enough play in it so it doesn't bind, or to the point it would break something possibly? Keep us posted Mike
