Exhaust Manifold Leak
Ford has a famous Long history of - Right exhaust manifold leaks.
My '94 was bad, so bad it took the plug wire boot insulation off, cracked, burned off, causing mis-fire, with the plugs grounding out on the manifold.
Looking at the rust crusted bolts, thinking........if one snaps off in the head
So, took the plunge, and was surprised how easy the bolts came out, once I got a socket "hammered" over the bolt head, and didn't snap one off.
New gasket, new manifold bolts, and no more listening to the poof-poof sound on a 4 hour drive, or even just around town.
When the vehicle is assembled most often there is no gasket used between the head and the exhaust manifold. With both surfaces clean, smooth, and rust free they will seal fine. It's when you take them apart years later and then want to reassemble them again that it can get iffy. With a cast iron manifold and cast iron head I have just used high temp silicone successfully but using a gasket is also OK. You do have to be careful when using a gasket though. Don't over tighten one bolt. You need to do all of them in steps or your could put stress on the manifold and cause it to crack. If using just silicone you don't have that problem.
I would suggest to remove the egr tubes to gain access.
The other problem is the studs nuts holding the Y pipe on the manifold.
If your lucky, you would not need to remove the nuts for the Y pipe, and just get the manifold pull back enough to slip the gasket in.
But, do spent the $8 - $10 for the stud kit, replacing the 'old-worn-out' bolts.
Once your have the manifolds in place, and torqued up, warm the engine up for about 15 minutes, let it cool for a couple hours, or over night, and then re-toque the bolts.
