My new truck is home!
Thanks to the advice and input from a few members here I made a choice in my seemingly never ending pursuit of a winter truck. I was able to purchase the truck for $700 and it cost me $256 to tow it home. So for a total investment thus far of $956 I have a 1997 F250HD 4X4 with the 5.8.
It's definitely rough but I think it's got potential!
Thanks for the positive comments. Originally I budgeted $2000 for a truck so going this route leaves me a little over $1000 to play with.
First step is to locate a coolant leak near the radiator and replace what's broken. Then it will get a full tune up. After that I need to fix the tcase shifter thats broken.
If all that goes well, it's going to get crazy
So I found my leak and it is the bottom corner of the radiator. I will be pulling that in the near future.
I realized the rear lead spring mounts were toast so a change of plans, off with its bed!
Crap that's not going back:
Taillight wire harness loosened from bed, filler neck bolts and clamps removed:
Didn't bother with the rusty nuts, grinded the heads of the bolts:
This bolt was still keeping the bed from coming loose so I opened up the hole, welded it to the bracing and removed the nut the old fashion way. Not much room with the front tank there!
And off!
I am going to knock all the scaly stuff off with a wire wheel and then por15 the whole frame and under the bed. I usually brush it but I think I'll spray it this time.
Where's the best place to get the leaf spring mounts? I'm thinking LMC?
Thanks!
And off!
Thanks!
Rizz0
09-21-2003 09:24 PM
