1949 Radiator support
Since the entire front end is suported by the core support, how did you get it out without your fenders dropping, unless they are resting on the frame horns. Just had mine apart, had the opposite problem, tool much gap. The three bolts go though the fender support, inner fender then into the core support. You may have to jack your front fenders up in the front to get it all lined back up. Good luck.
From my experiences messing with these front clips this will probably be more than a one man job as it might take a couple of buddies to gently pull the tops of the fenders away from each other. Maybe it will flex enough for you to slip the radiator support back into place.
With a little bit of luck and some patience you can probably slip it back in there.
Good luck
Bobby
Good luck
Bobby
"can't get it back in..." is a rather nebulous description of the issue. Do you mean you can't get it to go between the inner fender panels, you can't get the spring mounts in place, you can't get the bolt holes to line up? As said the front clip should not be attached to the frame any place, if it is, that is likely the issue. The clip should be installed after the radiator support is in place and squared to the cowl, not the other way around. If the inner fenders are bolted to the fender braces, then those bolts could also be the problem, the fender braces should be bolted to the radiator support while clamping the inner fender panels in between. Maybe this will help:
SixtysixF250
12-21-2017 06:49 PM
Colorado Highboy
06-24-2016 01:54 PM
