Standard transmissions, where have they gone?
#46
#47
I like autos. I also like power windows and locks, cruise control, power seats (with heat), air conditioning, power mirrors, you name it. I've driven manual-everything no-a/c trucks all my life growing up, now it's time to sit back and just relax and drive.
But my hobby cars are all manual trans.
#48
#49
It really is too bad that you can't configure things the way you want. You have to get everything as part of a package.
My ideal truck would have:
Manual Transmission
Manual 4WD
Manual hubs
Manual windows
Air Conditioning (With the manual controls, none of this electronic climate control BS)
Cruise Control
Plastic floor
Heated leather seats, but not power
Keyless entry (which would require power locks, otherwise I'd prefer manual locks)
Sent from my HTC ONE using IB AutoGroup
Manual Transmission
Manual 4WD
Manual hubs
Manual windows
Cruise Control
Plastic floor
#50
A manual takes less thought than an automatic for me. I don't have to think about what gear I'm in, or need to shift to if I should need instant torque to the road in a pass or to crest a hill... It's just ... well... automatic.
With an automatic I always have to consider if the kick-down detent is going to catch when I put my foot down... or will it leave me sluggish in the passing lane creating a failed attempt to pass? Should I just go ahead and kick it down... wait... PRND21... where are 3 4 and 5??! 1 and 2 put too much torque on the road for this ice. Lets start in 4... I said 4. I SAID 4!!!! Screw it, I'll walk.
#51
I don't drive on ice. Manual or auto doesn't matter on ice. As for passing, this is my 3rd truck with an auto and I have never ever had an issue with passing. It's not like there is a high failure rate for kick-down during the act of passing that leads to collisions. A worn clutch is just as likely to start slipping during a pass or when pulling out into traffic.
As for power windows and seats breaking, why not just fix them? Why ride around with a broken power window or seat and think you have to live with it? People that you see opening their doors because they can't roll down their windows are just the kind of people that ride a vehicle until it just dies under them from lack of maintenance. Fixing these things isn't rocket science.
#52
#54
Reminds me of my 1960 Impala; manual steering, manual brakes, manual windows and seats, 3 on the tree with OD, no AC and a 283 2bl.
Somehow managed to drive it just fine and the roads were full of similar vehicles in the mid 60's.
Something to be said for a simple truck although power steering and brakes are nice these days.
#55
Here are a couple of manual trucks used as trucks.
2000 Ford F250 Manual 4x4 Diesel - Truck For Sale
2002 Ford F250 Manual 4x4 Diesel - Truck For Sale
#56
We all have busy lives. But how long do you think it would take to diagnose and repair a power seat or window, when and IF it ever failed?
Every manual trans truck I ever owned needed a clutch/pressure plate, throw out bearing, or slave cylinder at one point during my ownership (in fact had to rebuild the trans on 2 of them). The 3 auto trans trucks I've owned needed nothing except the regular fluid changes. That leaves me time to run the farm and play with my kids. Auto trans aren't fail proof, but I can certainly say I've had far better luck with them.
#57
You may have never had a problem with anything automatic or power related, but I have never owned a vehicle with power windows or locks that I have not had to change the motor or actuator on. Never had to do that on a manual lock/window vehicle. I have also never owned an automatic that hasn't required fluid and filter changes or had to have a new transmission put in it at about 150,000 miles. Never had to replace a manual before.
#59
Let's see:
gas or diesel...
2 wheel drive or 4 wheel drive...
which oil to use...
cowboys still America's team...
ford, chevy, dodge...
all questions without answers -
only opinions, which USUALLY can't be changed
So get what you want .... and I'll get the latest with a manu-automatic that can tow my beast of an rv and do it as slow or fast as I want in the gear I want...
I just got back from 1000+ miles and would put it in tow/haul for stopping,
manual 6th gear for keeping it in high gear and let the turbo pull the hills without the drama of downshift, upshift, etc...
gas or diesel...
which oil to use...
#60
