We need to know under what conditions it whines. What speed? Under power or slowing down? What gear, or does it change with the gear? Gives us a few clues, please.
Hmmm...well...I primarily notice it at low speed...driving through a parking lot, etc. Its also been shifting a little more difficult in the last month or so. Maybe the trans is low on fluid...90 weight gear oil/right? Doesn't the transfer case also take 90 weight gear oil?
I don't know what the tranny takes as you didn't say what tranny you have, but an NP208 t-case takes ATF - not gear lube. Could also be the power steering pump low on fluid.
Several different 4-speed trannies with granny 1st gears were used in these trucks. I don't know what lube each takes, but you can go to the stickies and find pictures with which you can ID your tranny. Then you can google what lube it takes.
The NP208 t-case has a red label on it that identifies it.
Where does the whine come from? The engine compartment? The rear axle? Underneath you? There's a lot of things that can whine on an old truck like this, from a lot of different spots. Mine's always given a weird whine in first gear (I have a C6 auto, though), but it's never ever given me any trouble.
Yes, I'm fairly familiar when automatics whine...I've never had a manual (which is what I have) whine. The sound...seems to come from under to in front of me...my best guess...is its the trans or possibly front axle. I'll do more troubleshooting this weekend...checking fluid levels, etc.
