H4 headlight upgrade problems
Old 10-01-2014, 09:00 PM
hhight's Avatar
hhight
hhight is offline
Unhappy H4 headlight upgrade problems
Hey, folks
Trying to do a headlight upgrade with a relay harness I got from Amazon. That may be the first problem, but it was "redesigned" with more robust relays, blah blah blah....
Anyway, my headlight switch is working fine. I unplugged the new harness, plugged in one of the old bulbs, works fine. Plug in the harness, nothing. I've checked my wiring - orange plug goes to old headlight plug, blue plugs go to the new lights, red to battery + side, and black to ground. Cleaned the ground area with a wire brush, no paint, rust or dirt there. Inline fuse not blown. All electrical connections cleaned with DeOxit. Relays (one is 4 pin, one is 5) are in their correct places.
All I can figure is that the relays are bad. I hear no click when turning on lights. Marker lights and clearance lights work fine. New bulbs tested and working plugged into old plug.
Tomorrow I plan to hook the black to the negative battery post just to eliminate a bad ground problem.
Am I leaving anything out? I sometimes don't see what's right in front of me...any help is greatly appreciated! Thanks!
Old 10-02-2014, 07:15 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
If you want to investigate any further, you will have to get a wiring diagram and start probing the new wiring with a testlight or voltmeter.
Old 10-03-2014, 11:34 AM
hhight's Avatar
hhight
hhight is offline
will I ever learn....
OK, self, be more thorough when diagnosing a problem. Don't run to FTE and bug people for answers when it was a bad crimp connection in the wire you had to extend.
Gee whiz. Sorry to waste y'all's time! I promise to be more methodical and thorough in the future!
Old 10-03-2014, 11:42 AM
Franklin2's Avatar
Franklin2
I am glad you wrote back in with the fix. It's always something simple, it's just finding it.
hawkrider
11-07-2018 07:08 PM
DCRB
Aerostar
18
05-20-2012 09:05 PM
GLL-LLC
1999 to 2016 Super Duty
12-06-2010 10:07 PM
loyal
Electrical Systems/Wiring
06-14-2009 03:46 AM
wbhinton
07-20-2007 06:19 PM
Quick Reply: H4 headlight upgrade problems
