Vin help
Old 10-01-2014, 03:14 PM
toyomaz's Avatar
toyomaz
toyomaz is offline
Vin help
Hi guys, I found a 2005 f250 at junkyard 4x4 vin # 1FTNX21P24ED30885 would like to take the rear springs and sway bar, will this fit my 2002 ex? Anyone know how to decode the vin? That's guys
Old 10-01-2014, 03:48 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
This truck has P code springs.
Old 10-01-2014, 03:58 PM
toyomaz's Avatar
toyomaz
toyomaz is offline
Thanks. Will they fit?
Old 10-02-2014, 05:18 PM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
They will fit. I'm not sure what the P code spring rate is... there are charts on this forum with that info.
Also, on the sway bar, you may want to measure it. There is a 26mm (about an inch), and a 30mm (about an inch and a quarter). The mounting hardware is the same, but the bigger bar is better for the X.
Good luck!
Old 10-02-2014, 06:25 PM
mecdac's Avatar
mecdac
mecdac is offline
The SD received suspension upgrades in '05 that the Excursion never had, I would not be so sure that those springs would be a direct fit.
Hopefully, someone with more knowledge of the suspension upgrades will chime in.
Old 10-02-2014, 06:35 PM
holeshotwalt
The front was changed to coil springs, but the rear kept the leaf style and they're interchangeable with ours up until '08 when they went with a longer leaf. I believe they changed the code rating in '05 (a B code was changed to a ?? code, same spring). Just to keep things confusing, apparently!
Old 10-03-2014, 08:04 AM
RobRoss's Avatar
RobRoss
RobRoss is offline
I ran the vin and it was built with B Code rear springs with the overload. Hard to say if they are still on the vehicle. Looks like it's an even smaller rear stab bar also, ~18.5 mm.
jpr38057, what are the specs on a P code?
Old 10-03-2014, 02:58 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
My Ford parts look up doesn't give me the specs.
Not sure what lookup you are using but looking at the build sheet from Ford it is built with a P code rear spring, not a B. The P spring has an overload, the B code spring for the 2004 F250 did not have an overload.
Old 10-03-2014, 04:48 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
I'm using a Ford system to look this up. The rear spring part number tied to that vin has the same specs as a B. Does your book list a part number for the P code?
Old 10-03-2014, 08:52 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
3C3Z-5560-CA is the part # for the spring per the vin given and is showing a P code. That also is the same part # given by HVBOM.
3C3Z-5560-BA is the part # listed for a B code on a 2004 F250.
4C3Z-5560-MA is the part # listed for a X code spring on a 2004 F250.
Old 10-03-2014, 08:57 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
First two springs have the same primary and secondary rates with the exception being the -CA has an over load. I'm using HVBOM but have also read the prints.
Thanks for the part numbers!
BRONC-OH
1983 - 2012 Ranger & B-Series
12-17-2015 04:34 PM
The protege
02-16-2015 05:43 PM
bigwhitetruck01
02-14-2012 10:15 AM
OLDBustedKnuckles
11-08-2008 08:32 AM
snowfighter
02-25-2003 11:48 AM
Quick Reply: Vin help
