C6 lokar shifter
Old 10-01-2014, 10:24 AM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
C6 lokar shifter
Trying to install lokar c6 shifter and lokar kickdown cable. I'm not sure how to remove factory shifter. Cut it off? Instructions aren't very clear. Anyone have any experience with this kit?
Old 10-01-2014, 11:20 AM
Normalbloke's Avatar
Normalbloke
Normalbloke is offline
I just cut mine off. I've yet to drive mine, so I've kept the part just in case I need to weld it back on!
Old 10-01-2014, 11:55 AM
jrockdiddy's Avatar
jrockdiddy
Lol! Do u have any pics?
Old 10-01-2014, 12:04 PM
Normalbloke
Not at the moment! Just use your common sense. If you offer up your new billet Lokar shift lever, you'll see where it needs to be cut. Just use your noodle with regards to heat and swarf/grindings with regard to the seals that are in there.
Old 10-01-2014, 05:08 PM
jrockdiddy's Avatar
jrockdiddy
I figured it out and I was able to leave old shifter on. I'm posting these pics for anyone in the future who might need some pics.
Old 10-02-2014, 01:56 AM
Normalbloke
I'm glad it worked out. Mine is a column shift from an Ididit column, using a rod connection. This meant that the new shifter lever had to be at the 8 O'clock position when in park, which directly conflicted with the original shift lever.
Thanks for sharing the photos. I wasn't being obtuse when I said I couldn't get a photo, I'm away from the truck for a few days!
Old 10-03-2014, 01:11 AM
smallello's Avatar
smallello
smallello is offline
Mine was already on the trans when I got the truck. Looks like it was removed. Maybe it needs a puller to remove it?
Is your shifter a cable or linkage?
Here's a pic of mine:
Old 10-03-2014, 06:30 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,132 Likes on 2,656 Posts
Attachment 107298
What is the second strap for?
Old 10-03-2014, 11:29 PM
smallello's Avatar
smallello
It is how the mounting plate is attached to the trans. Sort of like this one:
Old 10-04-2014, 07:58 AM
56panelford
Gotcha, I was thinking it may be like that just wasn't sure, thanks
Old 10-08-2014, 09:15 AM
jrockdiddy's Avatar
jrockdiddy
Finally buttoned up the shifter last night, after installed threaded rod, the shifter is very difficult to shift through the gears. Feels like it is binding on something.... I couldn't find anything though. I disconnected threaded rod, and it shifted easily. Not sure what's going on
Old 10-08-2014, 01:34 PM
smallello's Avatar
smallello
I had a similar problem with mine. The rod was too short on it when I got it.
I had to move the shifter back on the mount plate and make a longer rod. The PO had it mounted too far forward.
The position of the shift lever is important too.
Is the rod very tight when installed? It should have some play in it.
Old 10-08-2014, 08:25 PM
jrockdiddy's Avatar
jrockdiddy
What rod are you referring too? The threaded rod connecting shifter to tranny shift lever?
Old 10-08-2014, 10:41 PM
smallello's Avatar
smallello
Yes, this is what I started with, You can see how short the rod was and how far forward the shifter was mounted. It was causing it to bind.
I moved the shifter back on the plate and made a longer rod. Lokar says the rod does not need to be bent... but I made a bend in it anyway. Seemed like the thing to do at the time; but it really didn't need it. I didnt have the threaded rod so I made it out of solid rod and tapped the ends.
My shifter lever is further forward than yours also. Yours looks like 2:00 to me. Can you bring it to 1:00 or is the old lever in the way?
Old 10-09-2014, 08:43 AM
jrockdiddy's Avatar
jrockdiddy
Attachment 107576
I will bring it to 1 o'clock. Will post pic later
Quick Reply: C6 lokar shifter
