1984 E350 Box Van
1984 E350 Box Van
Hi everyone, I am new to this site with a "new" acquisition of a 84 diesel E350 which has the econoline chassis and an aluminum Grumman Olsen 12ft box. It has been sitting for a while and I am going through the electrical getting all the lights to work. All was going well except the front side fender marker lights have no power getting to them. I noticed that the horn button on the steering wheel is broken and as a result the horn does not work. It looks like the wiring to the side markers are in the same loom as the horn and was curious if they may be tied together. I am also looking for a replacement horn button assembly but have found that cruise control models of which mine is not are different. If anyone can point me in the right direction I would appreciate it. Thanks. By the way I have checked the fuses and all look good. Truck was owned by a local Budweiser distributor and had a very good maintenance history.
Randy
Randy
The wires might run through the same harness, but I'd wager that they have no connection, electrically. You can verify this by looking at the fuse box diagram.
My money is on a broken/disconnected body ground for the marker lights.
Are there wires for the horn hanging out of the steering wheel?
Randy
