Fuel Injector does not look right
Not taken apart yet But wondering if the shop I had taken it to could have installed the wrong injector if that could be possible. just shooting in the dark here.... Can a piston really hit the fuel injector?
I know i will have to pull the heads to look further as I bought a snake camera which is to wide for the injector port to see what damage is.
That doesn't look like an impact. It looks like either the tip broke off or there was detonation that melted it.
I do not know how you could get the wrong injector. As far as I know there is no other engine that uses the same injector body diameter. I could be wrong....someone will correct me if I am wrong.
If you can find a used injector to put in that is KNOWN TO be good by all means go for it.
If it was me, I would pull the GP and see what it looks like before I went any further. If it looks anything like this, I would install the injector and do a compression check. If it is low, I would do a leak down test.
If you have access to a bore scope, you could have a look into the cylinder with the injector out.
Engine was lagging made it to a shop who diagnosed and replaced the injector after 120 km i had to pull in to another repair place which pulled the injector out and looked liked the pic.
I then had the truck tow it to ontario where it sits now in the driveway. the engine still turns freely.
This is a 2003 truck, correct? That said, you really need to evaluate how money it is worth to repair a 12 year old vehicle. At this point, your next course of action shouldn't anything else other than getting your hands on a borescope to have a look/see into that cylinder. If there is even any damage to the piston/cylinder head at all (which I'm almost beyond certain there is), the most cost effective repair will most likely be an engine replacement with a known, good, used 2003 engine. If you even look at the cost of all the parts you are going to need, not to mention the added labour the of disassembly/assembly it's going to climb up either pretty close to, or maybe well surpass the outright cost of replacement with a GOOD used 2003 engine.
