First Post and Rebuild of oil cooler, Got Leak problems, need help!!
Old 09-30-2014, 08:23 PM
Broke and Broken's Avatar
Broke and Broken
Broke and Broken is offline
Thumbs up First Post and Rebuild of oil cooler, Got Leak problems, need help!!
Old 09-30-2014, 08:32 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
Welcome to the site.......
Now a little more information is needed.
year of truck
your location
What work did you just do?
What are the specific issues? Where are the leaks etc...
Old 09-30-2014, 08:38 PM
Broke and Broken
could i have bent the housing? is this common? for newbies.....
Old 09-30-2014, 08:40 PM
Broke and Broken
the leak is from the front at the port area. at the two center bolts
Restlesswildman
What is leaking? Coolant or oil? Where is it coming from?
Old 09-30-2014, 08:41 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Seriously?
At this point it could be the rear diff leaking for all we know. Where is your leak? You can't post a question without providing some basic info.
Old 09-30-2014, 08:42 PM
Broke and Broken
2004 F250 PSD 6.0 late model, changed the egr cooler and the oil cooler. water pump, and radiator
Old 09-30-2014, 08:43 PM
Restlesswildman
once again where is the leak?
Old 09-30-2014, 08:44 PM
Broke and Broken
lol...sry just getting ragged on by the missis
Old 09-30-2014, 08:45 PM
Broke and Broken
looks like center of oil cooler at two bolts in the center.
Old 09-30-2014, 08:47 PM
Broke and Broken
i removed the intake and it is right below the throttle housing, under the test port area,
Old 09-30-2014, 08:48 PM
Broke and Broken
test port*
Old 09-30-2014, 08:51 PM
Broke and Broken
the test port has the brass nut and a plastic cap in the front center of the oil cooler housing
Old 09-30-2014, 08:54 PM
Restlesswildman
Did you make sure to A) put all the new o-rings in place? B) Torque all fasteners when reassembling?
If the answer is yes....then it is possible the oil cooler lid got cracked.
Old 09-30-2014, 09:32 PM
Broke and Broken
Yes i did the o rings and torque to spec. i did not remove the brass fitting at the test port area. do i need to remove the plastic cap and brass fitting to replace any o rings there?
Thanks for the reply's!!!
If i did crack or bend the housing, can i reuse the new o rings and gaskets if not damaged?
Quick Reply: First Post and Rebuild of oil cooler, Got Leak problems, need help!!
