2006 F150 No start
2006 F150 No start
I just went out to move my truck to take out garbage and it cranks but doesn't start. It is 4.6L 4WD. I sprayed ether in intake no change. Checked all fuses all good. It has been raining pretty hard the last 3 days and it has been sitting in rain all 3 days. I checked for codes with a simple code scanner no codes. But the code scanner I used is not able to do KOEO or KOER tests. I know it needs new plugs but it has never sputtered or died on me. Has slight misfire but not engine stopping. I havnt had any check engine lights or problems before.
check the fuel pump controller under the spare tire. The aluminum case on the steel crossmember causes the aluminum to rot out. Mine was still fine electrically somehow, but was broken wide open. They can lead to intermittant starting issues and no starts. Dorman makes them now so you don't have to go to dealer and Dormans come with rubber stand offs
FX4-350
35
01-11-2014 05:46 PM
Howling
12-18-2010 08:12 AM
snurchi
09-07-2010 09:05 PM
slpin
1978 - 1996 Big Bronco
09-29-2006 10:14 PM
