Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Air Conditioning Upgrades!
Old 09-30-2014, 06:58 PM
thekingofcows's Avatar
thekingofcows thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
Howdy there folks. I've been going through my A/C system. I've cleaned up the ac box and vents, resealed the vent flappers, installed a new heater core, new blower motor etc etc.
I had some new lines made up to replace the 30 year old dry rotted specimens. Here's a terrible picture of the one of the new hoses...
Now I'm at the condenser. I would like to run 134a. But I figure like most systems designed for r12, the condenser will be too small. I'm thinking about buying a larger universal condenser to retrofit into place to make up for the loss in efficiency from converting to 134a.
I'll probably get one similar to this.
Have any of you done this? I like to see your setup and see how it works. Any and all thoughts are welcome.
Thanks
---Cows---
__________________
"If you can't fix it, Tear it Up!"
Old 10-03-2014, 02:33 PM
SteelSteeds's Avatar
SteelSteeds SteelSteeds is offline
SteelSteeds is gaining momentum as a positive member of FTE.
I've been contemplating doing the same thing with my Bronco. I will likely buy the complete kit, something along these lines:
Nostalgic AC - Complete Ford AC Kit - Select an Evaporator - Stock Comp. Mount - Ford AC Kits For Trucks - Ford Complete Kits - Complete A/C Kits
They sell many individual parts, including condensers:
Nostalgic AC - Aftermarket AC Condensers
__________________
---Lance---
1979 Bronco - 429/C6/NP205
1979 F-150 2wd - 302/C4 - Indianapolis 500 Official Truck
and a bunch of Mustangs...
Old 10-03-2014, 06:51 PM
psychlopath's Avatar
psychlopath psychlopath is offline
psychlopath is gaining momentum as a positive member of FTE.
I guess I can't say that I've DONE it, because I haven't figured out how to buy the lines I need to actually run things, but I installed the condenser off of a 2001 Jimmy. It fit ALMOST perfect in my 79 and was very easy to mount.
If you were interested in buying one of those it would be worth a trip to a junk yard to take a look at them first and pick up the mounting brackets with their little rubber isolators before hand.
__________________
-FAR 65 Compliant
Old 10-03-2014, 10:55 PM
phillips91 phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
Subscribing. Will be doing this sometime soon too.
__________________
Josh P. Moderator Super Duty Forum
2000 F-250 5.4, manual, 4x4, 4.10 rear.
1992 Bronco 5.0, auto, 4x4, 3.73 rear
www.ford-trucks.com/guidelines.html
Old 10-04-2014, 02:29 AM
I think I've about figured out what I'm going to do. I'm going to get the largest modern universal parallel flow condenser I can fit (much more efficient design than tube and fin condensers on our trucks). They're pretty cheap on eBay 50-100$ Once it's mounted I'm going to get some lines made for it to accommodate the factory drier. There all common fittings so it shoulnt be too much trouble.
If you want to make a custom line the easiest way I've found to do it is take the fittings to a hose shop. Most common fittings they'll probably have, but the oddball vehicle specific fittings they should be able to braze to one of their own fittings. If you look at my original post, that's what they did on my hoses.
Old 04-26-2015, 07:46 PM
So this all I have done in a few months... I ordered a parallel flow condensed and mounted it in place of the factor condenser.
Now I just need to mount the sanden air compressor, and drier and make up some lines. Maybe my next installment will be a little quicker!
Similar Threads
Heater/ac wires. What goes where? thekingofcows 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-08-2014 10:02 PM
Question on An Axle thekingofcows Offroad & 4x4 11 04-21-2013 10:51 AM
My run of the mill homemade bumper. thekingofcows 1973 - 1979 F-100 & Larger F-Series Trucks 11 02-18-2013 12:41 AM
How bout a redneck gun turret? thekingofcows 1973 - 1979 F-100 & Larger F-Series Trucks 24 03-29-2012 09:53 PM
2$ Door Seals thekingofcows 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-20-2012 02:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
