Nothing at all Shawn. Winch gave up the ghost but covered under warranty. Just havent replaced it yet. Only other things I need to do to the truck are allmaintenance items. Namely replace the rear pads.
First one I had installed was replaced because of the accident back in november so this is the replacement. Will power out but not power in. Solenoid is good I figure the terminal could have had an issue that got missed. It happens. Nothing to be worried about. Just a bit of time to swap it all out. Shouldnt take me more then an hour or two.
thats what they said about mine.. "works for SRW but not DUALLY" yet both carried the same front axle?? only difference is the dually had a spacer on the front.. easy enough to remove to fit the hubs on.. then reinstall..
